warhead20022002
03-17-2005, 07:52 PM
1998 camaro, disk brakes all around. my car is only stopping with the front brakes only. i was told it was a valve or something. i lifted the back wheels and i put it on drive and i pressed the brakes hard and the back wheels didnt stop at all. and when i drive and stop the front sinks too much.
help would be apreciated.
funina91ss
03-17-2005, 08:15 PM
I would try bleeding the bakes first before replacing anything. Also check your pads when you have the wheels off.
blackztpi
03-17-2005, 10:08 PM
check your back calipers, and if the pistons are moving in a out. also make sure the master cylinder is pumping to the back brakes. let us know from there
warhead20022002
03-18-2005, 10:17 PM
i will try that as soon as the weather clears up. i will keep u guys posted.
but thanks for the help.
