rear brake problem
fearnside5
03-15-2005, 06:55 PM
Noticed the rear wheels turn with the brakes applied while on lift. If you spin the front wheels and hit brakes they stop. Anybody run into this before?
blackztpi
03-15-2005, 10:56 PM
well, the front brakes are accountable for 60-70% or your braking, but it should still lockup easily. 1)make sure your pads are good and intact (assumnig u have disks) 2) if pads are good, check for piston possibly being stuck in the cylinder. corrosion or something over a period of sitting and weathering can possible cause it to stick permanently in worse case scenario.
fearnside5
03-16-2005, 07:31 AM
my car is a 95 Z A4 with rear disc. I was thinking the same thing so I bought new hoses and calipers. I'm going to install today. I'll keep you posted with my results.
FastWhiteTA
04-25-2005, 12:34 PM
Hey man, what came about from this? I am having the same problem! I have an ABS light on (ever since I installed my elec water pump over a year ago) and I just found out the rear brakes aren't working...could they be related? Emergency brake works fine though...just nothing in the rear when I apply the pedal.
fearnside5
04-25-2005, 08:41 PM
new calipers and hoses fixed my problem
