Strange 12 bolts on sale!
tbyrne
03-14-2005, 04:48 PM
Another March Madness offering from TBYRNE Motorsports. We have the Strange 12 bolts on sale though Sunday evening (March 27th) -
Strange 12 bolts -
PRG210-PRGOP8 - Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) - Regular price $2429.99 - sale price - $2229.99
PRG210-PRGOP-14 - Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) - Regular price $2429.99 - sale price - $2229.99
Options -
R5206 Upgrade to aluminum support cover $149.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings.$229.99
gmbbpcore - Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars..$229.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763). Discounts can not be combined. Be sure to note where you saw our ad so we know where our advertising dollars are working!
tbyrne
03-21-2005, 01:55 PM
1 week left!
DTL504
04-08-2005, 08:51 PM
Let try this again, I went to Strange Engineering Thursday to pickup a catalog since I have been thinking about another rearend for my camaro.
Lets get a group buy going again!
DTL504
04-09-2005, 12:10 PM
Lets get this group purchase going.....I need the PRC200!!!!
tbyrne
04-09-2005, 11:23 PM
We'll do this again for 5 or more orders.
DTL504
04-10-2005, 01:28 AM
Can you list the parts/setup for the 3rd gen that might be interested in the
PRG200 Strange rearend with price non ABS.
