problem with 3rd
Old Mar 14, 2005 | 12:41 PM
ericz28w's Avatar
problem with 3rd
ok guys this lil problem has been goin on for a couple months, and is strarting to annoy me. when im in 3rd decelarating, it throws it into nuetral. no other tranny problems so far. so im not sure where to start
well let me know guys thanks
Old Mar 14, 2005 | 01:03 PM
teke184's Avatar
Re: problem with 3rd
bad synchros
do a search maybe you'll get more info
Old Mar 14, 2005 | 01:08 PM
Z28SORR's Avatar
I believe the two most common problems with these transmissions are bad syncro's and bent shift forks.
Usually this problem is caused by the syncro. not being fully ingaged. Which would indicate a bent shift fork.
P.S. If you have an aftermarket shifter, make sure the stops are adjusted correctly.
Magenta_Hearts
Mar 30, 2015 09:42 PM
simple
Aug 2, 2002 03:30 PM
19redta96
Jul 23, 2002 12:25 PM
stars1010
Jul 15, 2002 03:51 AM
