TireMarx723
03-13-2005, 08:58 PM
Im curious to see the bulge on them..post pics or links if you can
any1 running 295 on 9.5" rim?TireMarx723 03-13-2005, 08:58 PM Im curious to see the bulge on them..post pics or links if you can Black_Z28 03-13-2005, 09:09 PM This is probably the best one I have. It's a 295/35/18 on a 9.5" C5 wheel. Link (http://memimage.cardomain.net/member_images/11/web/419000-419999/419544_34_full.jpg) Here's another: Picture (http://memimage.cardomain.net/member_images/11/web/419000-419999/419544_32_full.jpg) Zack 03-13-2005, 09:19 PM a 295/35 will fit with not much buldge. well that was the case last week when i mounted up a used 295/35/18 toyo on my 9.5 wheel. Problem with me was it didnt appear any wider than my 275/35/18 yokohama, and the extra sidewall height turns me away from that size as well I also tried to mount up a 295/30/18 pirelli...I couldnt get it to seat the bead and air up, and it already buldged out badly TireMarx723 03-14-2005, 12:50 AM what brand tires are u runnin black z? where in mn u from? im on mnfbody also Black_Z28 03-14-2005, 01:27 PM what brand tires are u runnin black z? where in mn u from? im on mnfbody also Michelin XX3 I live in St. Cloud currently. I'll be graduating from State soon, so I'm not sure where I'll go after I graduate. RacingTiger04 03-14-2005, 11:49 PM hey black Z, hate to go off topic, but what kind of headlight blackouts are those? i havent seen any that dont wrap all the way around to the black semi-circle on the front clip, looks like those cut off with the hood lines. maybe those would look better than the AVS ones i had when i first got my car, i liked em in a picture on my car, but on person they looked awful, kinda bug-eyed cause they bulged out :( if i get blackouts i want a clean look, unless im mistaken and those arent blackouts at all 0_0 Black_Z28 03-15-2005, 04:51 PM I got the blackouts from Jegs about 4 years ago. They're made by GTS. I don't know if that company is still around or not. kingman109 03-18-2005, 12:34 PM I got the blackouts from Jegs about 4 years ago. They're made by GTS. I don't know if that company is still around or not. jegs old ones used to wrap around... then couple years ago they started making them cut like that... im pretty sure u can get them at any autozone too.. ohh and if u arent into the velcro i found if u mount the velcro tabs and pull off the velcro there is a hole.. place ur covers where they would go and mark the hole on them... tape it and drill it out then just use a black panhead screw and some winguts underneath. holds the blacksouts on and no one can pull them off unless u pop ur hood to unscrew the wingnut TireMarx723 04-27-2005, 02:06 PM i finally got mine on, looks good, i was scared for a little bit 4SFEDZ 04-28-2005, 03:13 PM mines in sig!!!! kingman109 04-28-2005, 06:49 PM mines in sig!!!! nice stance on the car... im looking to put the sportlines on my car this summer as well as looking into a center exhuast with valence (except i want the 2 tips) | ||
