jadams94ta
03-12-2005, 07:42 PM
can you just get a obd2 computer and put it in a obd1 car? will it hook up of do you have to do something to the harness
obd1 to obd2jadams94ta 03-12-2005, 07:42 PM can you just get a obd2 computer and put it in a obd1 car? will it hook up of do you have to do something to the harness Highlander 03-12-2005, 08:35 PM all you have to do is change knock sensors LiT1_up 03-13-2005, 03:16 PM What about the rear 02s? jay_lt4 03-13-2005, 03:25 PM obd1 to obd2??? are you sure you dont mean the other way around obd2 to obd1 all you do is change the knock sensor obd1 to obd2 many changes, the obd2 pcm uses a crank sensor, rear o2 sensors, different timing cover crank hub plus many other differences Highlander 07-03-2005, 09:49 PM The crank sensor is only used on 97s. | ||
