Is there still Zaino on my car?
My poor camaro has had a rough past year. I have used zaino on it all the way till i went to college last fall. I was living in a dorm and could not hand wash my car so i had to use the high pressure wash and soap for the year. Then over the winter i used mequires wax because all of my zaino was in colorado, 1000 miles away. Then i blew the engine and it has been sitting in a barn for the last 8 months. Now is the zaino still there or should i start over? Thanks
If you applied the Meguiar's wax over the Zaino, the Zaino was likely gone immediately after you applied the wax. If you last Zaino'd last fall, the Zaino would probably be gone now anyhow, even if you did not apply anything on top. Many products you apply over Zaino will stip it, so be careful in what you use as a substitute. It MUST be a completely nonabrasive wax or synthetic for the Z to stay.
You'll need to use DAWN again to strip the wax, then redo the Zaino with ZFX or Z1.
You can never HAVE too much, but it is possible to APPLY too much!
