8 & 9 mm Ignition wires for your LS1 or LT1
Maldo
03-10-2005, 02:05 PM
click here for more info and pictures (http://www.elitesparkplugs.com/Sparkplugwires.html)
Elitesparkplugs.com has the ignition wire for you that won't break the bank. Elitesparkplug.com Ignition wires are guaranteed for life!!! (note: Warranty does not cover burnt ignition wires) Our wires provide low resistance to get all the available power from your ignition coil(s).
Options
Many different colors to choose from.
Heat shield protection: (500 degrees of direct continuous heat and 1200 degrees of) Don’t be fooled by others who offer heat protection because this is just a sleeve they put on after the wires are made (covers)
And use heat shrink tube to hold the sleeve in place, (which crack or fall off exposing the ignition wire ultimately leading to sparkplug wire failure).
Elitesparkplugs.com does not do that our heat shield covers 100% of the wires and is integrated into the sparkplug boot ends.
Custom wire sets: got a custom set up and don’t want to cut crimp your own wires let us do the work for you. We make any length and configuration that won’t break the bank.
We also offer 10 mm solid core race wires (not recommend for daily use cars)
Maldo
03-17-2005, 11:50 PM
ttt
scubaz28
03-18-2005, 04:40 PM
Any discount? I would also be looking for spark plugs along with the wires.
Maldo
03-18-2005, 05:30 PM
Hi sorry at this time we do not have any dicounts on plugs.
thx Jim
