MyGreenBabyZ
03-09-2005, 12:03 AM
Ive been reading and reading about Dynamic compression ratios and quench distances and frankly ive been getting more and more confused. What does Dynamic Compression Ratio Really effect as far as drivability/power go? What about Quench? What is too small for either?
Here are my specs and some of the results I've gotten from Dynamic Compression Calculator By Patrick Kelley.
Camshaft: Advertised Duration: 279Intake/286Exhaust 113LSA 113ILC
Stroke: 3.750"
Rod: 6.0"
Head cc: 59cc
Piston to deck clearance: .010" (for calcs NOT set in stone YET!)
Head gasket: .039" crushed 4.125" bore (For calcs not purchased yet)
Pistons: Wiseco's Flat w/valve reliefs (-5.4cc)
When i do the Calculatons I get the following:
Static CR: 11.44:1
Dynamic CR: 8.55:1
Quench: .049"
The thing that gets me is that i DRIVE my car allot! My Z28 is my daily driver, so i decided on the 383 and the smaller camshaft for streetability(good throttle responce good low end) Is that DCR and quench going to work for street driving on premium 93 pump gas. Ive been told that 9.0 was the general limit, but i want to be safe.
I could also change a few things and use a dish piston to bring the DCR down but I feel it just looks TOO low, At least i think. Here are the calcs for the dish:
Stroke: 3.750"
Rod: 6.0"
Head cc: 59cc
Piston to deck clearance: .000" (for calcs NOT set in stone YET!)
Head gasket: .029" crushed 4.125" bore (For calcs not purchased yet)
Pistons: Wiseco's Dish (-20cc)
Static CR: 10.18:1
Dynamic CR: 7.64:1
Quench: .029" (but isnt it more because of the dish?)
Which way would be better to go? I do not plan on using a turbo or supercharger on this car, but I MIGHT put a 50 shot of Nitrous Oxide on it. Ultimately I want this to be good on the street and handle my daily abuse and last me a good long time. This motor's ability to run on pump gas(93 octane) and not have detonation issues is also important to me, i will be having a good dyno tune done.
So in summary:
1: What does Dynamic Compression Ratio Really effect as far as drivability/power go?
2: What about Quench?
3: What is too small for either?
4: Which pistons/setup would be better for my needs?
I'm SO very sorry for the length, but as usual THANK YOU GUYS FOR YOUR INSIGHT AND HELP ON MY PROJECT!!!!!!
:bow: :bow: :bow: :bow:
THANKS,
T.C.
Stroke: 3.750"
Rod: 6.0"
Head cc: 59cc
Static CR: 11.44:1
Dynamic CR: 8.55:1
Quench: .049"
Stroke: 3.750"
Rod: 6.0"
Head cc: 59cc
Static CR: 10.18:1
Dynamic CR: 7.64:1
So in summary:
THANKS,
T.C.
