Anyone know late model Dodge Rams?
Timberwolf
10-11-2002, 11:36 PM
I don't have a shop manual yet. How hard is it to swap rotors on the front of a Dodge Ram 4x4? Will I need any special tools? I've done old GMs and Fords where you need the special socket to remove the retaining nut. How's the dodge go?
Mine's a 99 1500 4x4
Dave89IROC
10-12-2002, 10:23 PM
It should just be the "hat" style rotors, they slide over the hub /studs(which are the sealed bearing, bolt in type), you may need a hammer to persuade the old rotor off, depending on the amount of rust inside the back of the rotor it may take quite a bit of pounding
