rossafenton
03-06-2005, 11:43 AM
Give me your thoughts on the 80mm throttle body and a intake manifold from BBK.
will these mods make the engine sound different?
Tell me your experience and comments.
Ross
98 SS
teke184
03-06-2005, 08:57 PM
sound different...NO...
more hp is questionable. probably but i havn't seen any tests on those yet so hard to say.
but the LS6 intake gains about 10hp at the wheels so i should imagine the BBK would gain similar.
Greed4Speed
03-06-2005, 10:50 PM
Unless you have the mods to support an 80mm Tb it'll probably kill throttle response.
Donny O
03-09-2005, 08:09 PM
same as with the old carburated engines. so many times i saw people take a stock 350 and buy a huge 750 or 850 for it and go slower and have drivability problems....because the engine was stock and didn't need more carburation....and I blow them away with my 500CFM 2bbl. know a guy that was putting our about 600+hp on a 750CFM carb. switched toa 850 and gained about 3mph but his et was the same. so even at those power levels a bigger carb didn't make much difference.
Antz97ZNJ
03-11-2005, 06:00 PM
You'll gain a 5-10 hp from the intake manifold...your stock tb is fine though, you wont gain anything from an aftermarket one
1984camaroz28
03-11-2005, 07:24 PM
buy a ls6 intake manifold and be better off BBK=JUNK
