How Close to 12's????
ChevyTuffD.A.
03-05-2005, 07:16 PM
Hey guys. I cant wait to get my car out for the spring and I have done a few things with the car over the winter. Ditched the 2.73 gears and put in 3.73's, got a custom tune from madz28, throttle body bypass, new plugs. I want to be able to break into the 12's on all motor with stock enternals. With the mods I have now is that possible. The only thing I have so far is an 1/8th mile time of 8.76 which I am told is equivelant to about a 13.5x when i still had the 2.73 gears, no tune and didnt yet have the throttle body bypass, this was also about 10 minutes after i made the 20 mile drive up to the track so the motor was already heated up. If I let the motor cool down completely and with the new gears and tune and bypass. Is it possible to break into the 12's? Thanks, Dustin.
MarkyMark
03-05-2005, 07:56 PM
You will need some sticky tires in order to do it......throttle body bypass wont do much for ya, the tune and gears should get you really close. With street tires I would say you will still be lower 13's.
ChevyTuffD.A.
03-05-2005, 09:19 PM
I run on Nitto 555R drag radials 24/7
DonHood
03-10-2005, 01:00 AM
Ran the times in my sig just a few weeks ago when the track opened. I'm hoping after I get some of my ignition issues settled, and a better 60' to be very close to the 12's. If not, then some 1.6rr's and 4.10's oughta help out. :)
Edit: My 1/8th times were 8.632 @ 84.10 mph
