Stripped bolt on positive side of battery. How to fix?
Old Mar 5, 2005 | 05:10 PM
stang_killa94's Avatar
The bolt that holds down the wire on the positive side of the battery somehow got stripped and now I have to move the battery around before i can start that car and sometimes it wont charge up because there is no connection. I tried just take the bolt out by twisting it but it just stays inside the red boot. Anyone know how to replace that bolt?
Old Mar 5, 2005 | 05:31 PM
Kataklysm's Avatar
Re: Stripped bolt on positive side of battery. How to fix?
As far as I know you need to get a new positive cable. Its a PIA to run it too.
Old Mar 5, 2005 | 06:41 PM
CMANZ28's Avatar
You can get a new bolt. When you wire an Amplifier into a car they make a special battery post. So if worst comes to worst you can use one the them.
Here is one on ebay for $1.99
http://cgi.ebay.com/ws/eBayISAPI.dll...755454358&rd=1
CmanZ28
Old Mar 5, 2005 | 07:02 PM
If it is the bolt, you can get replacements at any auto supply. If it is the battery threads that are stripped, you probably will have to replace the battery.
Old Mar 5, 2005 | 07:13 PM
Yeah its just the bolt that stripped, I guess my question should've been......How do I take out the old bolt? I tried to pull and screw but the bolt just spins inside.
Old Mar 5, 2005 | 11:43 PM
Mean Green Z28's Avatar
it'll come out if you tug at it long enough. You just have to pry it off the boot. I usually use pliers and press on the threaded side of the bolt and the edge of the boot and it pops right off. You'll get it
Old Mar 5, 2005 | 11:53 PM
Unscrew while pulling out.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
MislMan
Jul 19, 2002 11:41 AM
