LS1 and th400
sandking
03-05-2005, 12:30 PM
Will it bolt right up ? I have heard problems with flexplates or something that needed to be changed but cant remember, what was it if anything? thanks
sandking
03-05-2005, 12:52 PM
I did do a search, but did not get a good answer. All I gathered is that I will need a new torque arm, is that it?
BISHOP
03-06-2005, 08:34 PM
The Trans will bolt right up to the motor, you will not use the center top bolt and on some cases the bolt to the right of it. Use a TH400 convertor that has a Pilot extension. The earlier LS1 Flexplates have the TH400 holes also drilled in them. There are ways to mod a man. crossmember or just get a BMR.
sandking
03-06-2005, 11:37 PM
Thanks bishop
