Need instructions for replacing a broken M6 tranny mount
joey93turbo
03-03-2005, 02:14 PM
What's the easiest way to do it? any howto's or writeups on the board?
shouldaboughtthez
03-03-2005, 02:18 PM
http://www.installuniversity.com/install_university/installu_pages/sophomore_year/tranny_mount_m6.htm
try this.
joey93turbo
03-03-2005, 02:31 PM
Perfect, thank you.
shouldaboughtthez
03-03-2005, 03:43 PM
no problem!
valter
03-03-2005, 04:33 PM
That's overkill!!! No need to drop transmission crossmember at all. You can just put car on ramps, put jack where shown, remove tranny mount nut, jack a tranny a lil more, remove two other transmission mout bolts with open-ended wrench. Then remove old mount, put new. 15 minuts of work.
blind527
03-07-2005, 05:58 PM
I have one question about this. I know I jack the transmission near the transmission mount, but where do I put the jack stands to get the car up? Should I lift the car up from the front or the rear? I know where to put the jack stands, but which side do I lift up?
valter
03-07-2005, 08:35 PM
I just used Rhino Ramps for my front wheels. There was enough space to do all work from sides.
