teke184
03-02-2005, 03:40 PM
first off...stock LS1...
what should the compression in PSI be on each cylinder?
second...
i have a misfire problem, think it's a bad lifter. it is intermitant...misses on cylinder 7 for a few seconds, then runs fine...then misses again...etc.
can i just pull the sparkplug, put the compression guage on it and run the engine to test compression? should i unplug that injector?
or should i just test it by turning it over with the starter?
i'm worried that if i just do the starter it could be reading the time when it seems to NOT miss...
if i run it i should be able to watch it fluctuate (assuming it IS a bad lifter) from proper compression to a period of bad compression.
any help would be greatly appreciated
second...
