Help with stereo wiring
dabez1
03-01-2005, 11:30 PM
I know this doesnt have anythign to do with f-bodies but i need to figure out where the REMOTE wire that goes from the back of the stereo to the amplifier. This is the stock stereo of a 99 Tayota tacoma.
Theres so many damn wires in the back of the stereo. Any diagrams?
shoebox
03-01-2005, 11:56 PM
Doh! Isn't there a Tacoma forum somewhere?
:confused:
I just don't get it when someone says they know they are not supposed to post a question here and do it anyway. :shrug:
:D Is there a high percentage of f-body and Tacoma owners? I don't know. :shrug:
billsbird
03-02-2005, 04:04 AM
...go to the service deptment at a Toyota dealership.... Or parts....
They will know.... or I read that Toyota is recalling 22,000 Tacoma's. May be
the recall is for a missing stereo wire???? zzz
baxter96720.cz28.com
03-03-2005, 12:39 PM
A lot of the time the remote wire is blue. I dont know if that will be of any help to you or not. Good luck. :)
Javelin3o4
03-09-2005, 01:05 AM
http://www.precisionautosound.net/toyota-2.html
87-Newer diagram, colors may have changed as far as sthe diagram shows but it should use the same plug unless its amplified then it may just have 1 plug in the back that goes down to the factory amp that is uaually behind the radio console but would have the 2 standard toyota harnesses plugged into it just follow that one plug down if its like that. I would probably use pin c for the remote which should be ignition.
