WHat kind of gears
badasschevy625
03-01-2005, 09:10 PM
Hi i am going to be purchseing some 4.10s for my car and i dont have a dam clue what kind of gears to buy whats good pluses minus thanks for any info
93LT1355
03-01-2005, 11:23 PM
I'm ordering Motive 4.10 gears in about a week. I don't think you can really go wrong if you stay with known gear companys. I had Richmond 3.73's in my car for about a year and didn't have a problem with them. They whined but when I took that rear end out to sell to my friend, we readjusted them and they make no noise now. Good luck on your search for some gears.
Pro Built Automatics
03-02-2005, 04:33 AM
Give me a call at 8007763288 anytime past 11am pst, and I will answer your questions as to what gears you will need. Let me know?
CreatiVe2
03-02-2005, 01:21 PM
i have the motives.. and they are the best thing i have gotten for my car, performance wise.... they should have been installed from the factory!! no whine, i got them from www.ls1speed.com you MUST ge the install kit!!!
WestCoast96Z28
03-02-2005, 01:36 PM
You should also check if you have a series 2 or 3 carrier. I also have a 96 A4 with 2.73 gears, so I need a series 2 gears. You might be lucky and have 3.23 gears, so you can use the more popular series 3 gears. Makes a difference, b/c you'll almost never find used series 2 gears.
How do you know? Check your RPO codes on your driver side door. I think it's the "GU" series...that should say your gearing. Or look at your shifter. If the lowest selectable gear is "2" and then D and then OD, the you have series 2. If you have "1" and then "2" and then D...., you have series 3. But best to check the factor RPO codes to be sure.
Do this research before you buy your gears and have to return them.
CreatiVe2
03-02-2005, 01:52 PM
im petty sure the sock gears in the 96-94 for A4 was 3.23.... mine was 3.42 in a M6..... the older A4 (93-95) were known to have 2.73's
search aroudn the forum for "1996 stock gear ratio"
badasschevy625
03-04-2005, 08:28 AM
well i know mine has 3.23s
GreenDemon
03-05-2005, 04:01 AM
2.73s were standard on auto 4th gens. 3.23s were considered the "performance" axle and were an option, although they weren't marketed as such. Most people that bought autos probably weren't that worried about the ratios anyway.
