95 timing cover and opti wiring harness
Old Feb 25, 2005 | 11:34 AM
hawk232's Avatar
i need a timing cover from a 95, and a opti waring harness from a 95
Old Feb 25, 2005 | 11:36 AM
97bluebird's Avatar
Re: 95 timing cover and opti wiring harness
i have a timing cover from a 97 firebird....goto your local junk yard and buy the pigtail for 20 dollars thats what i done
Old Feb 25, 2005 | 02:23 PM
hawk232's Avatar
dont the 97's have the hole for some sensor or something? i dont feel like having to try to cap that off, thanks for the junkyard tip though
Old Feb 25, 2005 | 06:00 PM
97bluebird's Avatar
yes it has a whole for a crank sensor...its still in the timing cover...i wouldnt charge you for it
Old Feb 25, 2005 | 06:56 PM
hawk232's Avatar
ok, i appologize for my ignorance, but i have never looked at an opti up close, but im assuming that since the sensor is in there that the hole is plugged and i just wouldnt hook anything up to the sensor. am i correct? if that is the case then consider it sold, do you take paypal?
thanks
david
p.s. i tried sending this through a pm but your box is full
Old Feb 26, 2005 | 05:45 PM
97bluebird's Avatar
its cleaner now...sorry bout that.....just as long as you have a vented opti it doesnt matter. yes the sensor is there and all you do is forget about it. it doesnt leak or anything. just leave it unpluged. easy enough huh??? just make sure you have a vented opti in your car thats my only concern. ill pm you with my number and ill check into it to make sure.. i dont want to sell you something you cant use.
Old Mar 2, 2005 | 10:46 AM
97bowtie's Avatar
I have a front cover seal as well if you're interested. Check my sig.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
