jcolez28
02-24-2005, 07:21 PM
Whats the best way? I havnt had much luck with the engine degreasers? Thanks
Removing thick grease from engine bayjcolez28 02-24-2005, 07:21 PM Whats the best way? I havnt had much luck with the engine degreasers? Thanks ZaneO 02-25-2005, 04:03 PM Where is the grease at, and what products have you tried? jcolez28 02-25-2005, 10:57 PM Just noticed you have a 93 A4 too. I took off the accessory bracket and water pump to have them powder coated so the whole bottom of the engine area. Mostly just the years of taking things apart and spilling and then the build up. Ive tried the, warm the car and spray and rinse from the Zone. STP Gunk ect. I just wondered if anyone had discovered something that really works. Thanks ZaneO 02-25-2005, 11:02 PM Remember to be super careful with water around the opti. I use a diluted all purpose cleaner and a variety of brushes and mitts to clean the engine. You might try to wipe off as much of the excess grease as possible, and then try cleaning. jcolez28 02-25-2005, 11:43 PM I learned that valuable lesson once before. Now I guard it like my first born. Thanks moparman 02-26-2005, 09:53 AM In areas where there are no sensors, this includes the opti, try brake parts cleaner. Be sure to wear goggles. AutoRoc 02-26-2005, 07:20 PM A Spatula. Coat with PAM so nothing ever sticks again. :bow: Other than brake cleaner, I've never had anything remove grease. Camaro_Guru16NY 02-26-2005, 11:26 PM Brake cleaner is the way to go, jus watch your eyes and the area your cleaning cuz your paint will disappear if you carried away, lol -john jcolez28 02-26-2005, 11:36 PM Finally a good answer! Do I need to follow it up with water or just wipe it? Will spraying Pam really work? Thanks Camaro_Guru16NY 02-27-2005, 12:02 AM just wipe it put remember alittle bit goes along way... -john ws6transam 02-28-2005, 09:27 PM Have you tried Simple Green yet? I'm repainting my '84 right now, and I've been clearing a lot of old rustproofing off surfaces by spraying undiluted Simple Green and letting it soak for a while. Then, a bit of brush action wipes the gunk off. jcolez28 02-28-2005, 09:56 PM Oh Yeaaa!! Brake cleaner!!. I tried the simple green too. I used it after the brake cleaner to finish it off. They had four types at Zone and I read the chemicals and even the cheap 99 cent a can was the same. I bought it and the grease caked on for 12 years sprayed away like dry sand! Thanks!! | ||
