Newb needs help constructing his sub box.
AronZ28
02-24-2005, 02:38 PM
I need some advice on constructing a sub box that will hold my 12" Eclipse woofer in the driver's side rear trunk cavity.
How did you secure the box to where it won't budge when I drive like crazy?
If anybody would send me some dimensions or a design for a sub box that you have built, that would be great too. I'll fudge the dimensions a little to get the exact volume correct for my application.
How did you seal your box to where it is air tight? I figure I'll use some silicone cauk on the joints.
97FormulaWS-6
02-24-2005, 06:26 PM
For cubbyhole boxes, I typically use a combo of 3/4" MDF (For the baffle to mount the speaker) and fiberglass.
Most MDF only boxes I seal with Liquid Nails, works awesome for subwoofer enclosures and seals them right up.
Don't use Silicone to seal speakers to enclosures, it can react with the speaker surround/seals and cause problems. Most subs have their own felt seals that work well, and if you want extra sealent, then use some Plumbers Putty.
