1st and goal
02-24-2005, 12:50 PM
This is what my local tracks website says about relocating the battery to the trunk.
Won't the car still run if you hook up the push/pull switch to the positive side of the battery? How do make this work and be legal for track duty?
Master Disconnect Switch: Whenever a battery is relocated to the trunk, the vehicle must be equipped with an external disconnect switch. This switch must be clearly labeled and immediately disconnect the positive side of the battery. To determine if the switch operates properly a tech inspector will turn off the switch with the engine running. If this action does not shut down the engine then the switch is wired improperly and the vehicle shall fail the inspection. Drivers should ensure the alternator charge wire is routed to the battery side of the switch. This isolates the alternator from the rest of the electrical system. Drivers should check with the switch manufacturer to ensure it is properly installed.
