Fastbird93
02-23-2005, 07:33 AM
Has anyone actually compared the weights of the following two tires:
MT Sportsman Front 26 X 7.5 X 15
vs.
Pep Boys special, 165R15 or whatever the corresponding size is (can't think, too early).
They'll be going on a Centerline Telstar 15 X 4.
Stephen 87 IROC
02-23-2005, 09:03 AM
Since the tires are roughly the same size, I'd say the 165R15 should be a bit heavier because of the steel belts of the radial. The 165R15 will also be a lot cheaper and will last longer.
Doing a quick web search:
The MT 26 x 7.5 is 16 pounds
A 165R15 is between 16 and 18 pounds depending on the brand. Most are 16.
Fastbird93
02-23-2005, 12:06 PM
Good deal, thanks for the info.
maroon94z
02-26-2005, 01:15 PM
Good to know. I currently run the 165's, but have often wondered if my car would go faster on true front runners. Does anyone know? I would think the rolling resistance would be less with the MT's or any brand of belted front runner. Just curious if anyone has tracked this sort of thing.
mongse_1
02-26-2005, 07:04 PM
I'll weigh mine once they're mounted. I have 165s on a set of D-10 Bogarts now. They'll go on the same wheel.
Fastbird93
02-26-2005, 10:53 PM
Well, I can't say for sure how much of a difference there would be, but less weight is always better.
