Comp cams 306 for NON-LT1 factory hydralic roller
Old Feb 21, 2005 | 09:03 AM
groundpoundinlt's Avatar
i have a comp cams part number 08-306-8 for a NON-LT1 hydralic roller...i bought the cam in hopes of working in my lt1 and will not fit...this has the same grind number and specs as "the infamouse 306" for lt1s but is for any non lt1 hydralic roller
$150 shipped
Old Feb 22, 2005 | 05:02 AM
stealthblack's Avatar
Re: Comp cams 306 for NON-LT1 factory hydralic roller
Im interested, could you tell me the comp grind/part # so i can check the specs in their catalog[i saw 306 specs but didnt see the exact same one in factory hyd. roller section]--custom grind?thanks.
Old Feb 22, 2005 | 06:21 AM
this is straight from their website:
Part Number 08-306-8
Engine -9999 Chevrolet
305ci-350ci
8cyl.
Grind Number CS 290H-R12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.51 0.54
Duration At 0.006 Tappet Lift 290 307
Valve Timing At 0.05
Open Close
Intake 7 43
Exhaust 58 6
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 230 244
Lobe Lift 0.34 0.36
Lobe Separation 112
Recommended Valve Springs 987-16
this cam has the EXACT SAME specs as the 306 for LT1s
thanks
bubba
Old Feb 22, 2005 | 01:38 PM
Ttt
Old Feb 22, 2005 | 02:05 PM
thanks for the update man, im looking for a little hotter.Heres a ttt for ya.
Old Feb 22, 2005 | 02:33 PM
this has the same lift, duration, etc as the LT1 306 cam but its mad for any NON-LT1 hydralic roller
thanks
bubba
Old Feb 23, 2005 | 09:23 PM
Ttt
Old Feb 26, 2005 | 09:39 AM
Ttt....
Old Feb 27, 2005 | 05:20 PM
ttt
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
