Lowering with LT's
Old Feb 20, 2005 | 06:13 PM
Black6spdZ's Avatar
Lowering with LT's
I used to have a 93 z28 with a pro kit on it and liked the handling and the stance, i now own a 96 with hooker LT headers anyone have their z lowered with LTs and a pro kit?
Old Feb 20, 2005 | 07:10 PM
Beyonce Knowles's Avatar
Re: Lowering with LT's
I'd like to hear what people have to say, too. Seems to me like the maximum you could do would be 1", I can barely get over speed bumps with 2 people in the car as it is already.
Old Feb 20, 2005 | 09:30 PM
sc1twntrbo's Avatar
i have kooks long tubes and my car is lowered with hotchkis sprign that seemed to lower way more than an inch and i dont have any problems. the headers only hang down about as low as my slp sfc do
Old Feb 20, 2005 | 09:46 PM
ZaneO's Avatar
If your a cognizant driver, there won't be too many problems.
Old Feb 20, 2005 | 10:13 PM
DisturbedZ28's Avatar
you'll be fine as long as u avoid goin to ny or nj lol.....i had the pro kit w/ jet hot's on my 94..it wasn't that bad...just gotta beware of driveways and dips in the road etc etc....good set of shocks defintley helps alot(ie if they're adjustable..keep em on harder settings on the highway)...
Old Feb 21, 2005 | 12:03 AM
Eric @ DMS's Avatar
We have LT's on our SS with our lowering springs and have no problems. As was mentioned, just drive with common sense and you'll be fine
Old Feb 21, 2005 | 12:17 AM
revtime's Avatar
Common sense means there are places you won,t be able to go.
I have LTs on my 94 with an Eibach drag launch kit and the front was lowered about an inch.
I know there are certain places I avoid, speed bumps being one of them.
As long as you understand this and pay attention to road conditions you should be fine.
I have no backseat, so I have a one passenger limit. You won,t be able to tote around all your buddys anymore.
Old Feb 24, 2005 | 04:35 PM
96badbird's Avatar
with my hotchkis springs and billstein shocks, its a give take thing..... you give into the awesome looks of a lowerd car but you sacrfice being able to go alot of places ive often found myself in a new parking lot backing up and trying to find another route through speed bumps should be outlawed..... if you going with the hooker or the jet hot i suggest the mufflex y pipe so far its proven very strong and durable ( cause sooner or later your gonna scrape something)... . my car is droped 1.25 to 1.5 inches an if you look underneath my car there is literally 1.2 inces of space between the drives side exhaust and the road.... my advice HOLD ON TO YOUR STOCK SPRINGS in case you want to go back cause you sick of the occasionl metal scraping from underneath your car..... good luck
Old Feb 25, 2005 | 11:24 PM
fozziez28's Avatar
I have pacesetter long tubes and dms springs and my car is lower than a pro-kit.
The only things i normally have problems with is speed bumps and my cutout hitting just about everything. My headers and ypipe rarely hit. OH, dont hit road kill, it will send chills up your spine (it was a dead unavoidable racoon and boy did it smell nasty). Other than that, i havent had problems.
Old Feb 26, 2005 | 09:52 AM
Black_Z28's Avatar
What kind of LTs do you guys have? Cripes...you have issues at stock height? I think you should look into a new set of LTs if that's the case. I've seen TPIS LTs, and there's no fitment issues. They fit probably better than shorties. Anyways, I've seen a few people with the TPIS LTs and the ProKit with no problems at all.
Old Mar 2, 2005 | 06:53 PM
blind527's Avatar
What does it mean for a ORY to have all EGR and AIR and o2 sims? I thought the whole purpose was to not have those? I want to get an ORY with either Pacesetter long tubes or Hooker. I have visual inspection here, but not until May.
Old Mar 2, 2005 | 09:23 PM
Black_Z28's Avatar
The headers have the provisions for the EGR and AIR. Not sure what y-pipe you're talking about that has the O2 sims. I doubt you'll pass a visual if you get LTs without EGR and AIR. You may not be able to pass even with the AIR and EGR on the LTs. Totaly depends on the person doing the inspection.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
