The High lift 224/236 Ex cam
Schurters LT1
02-18-2005, 08:05 PM
This is the cam I am running in my 355 set up, BUT have a few ?
-What kind of rpm will this cam peak at...(heads AFR 210raceready out of box)
-I fig that the cam will hit the stock vavle covers...is there anything i cam do...(EMike I think hit his with a hammer) will this work , is there any pix out there, what can i do...
-I am thinking of using it with a 1.6 on both int/ex ....am i asking for @#$% here (i order the heads from AFR with spring for up to .625 HR)
-anyone have a half set of 1.52rr pro mag for 7/16 for sale.....
engineermike
02-19-2005, 02:14 PM
The cam or rockers are not what hits the valvecover. It's the poly-locks, which will hit regardless of which cam you have.
rskrause
02-20-2005, 10:49 AM
With good supporting valve train parts you should pulley the blower to peak at ~6,000-6,200rpm.
Rich
Schurters LT1
02-21-2005, 12:22 PM
Could i make power to( or spin it too) 6500rpm, or because this is a EX cam it will fall off at 6200rpm
engineermike
02-21-2005, 06:12 PM
My hp peak is at 6500 with this cam.
Schurters LT1
02-21-2005, 06:23 PM
EM, what springs do you have on your AFR210s....you make power up to 6500 then, falls hard or slow.
Schurters LT1
02-21-2005, 06:52 PM
Is putting a 1.6rr on the ex side a bad thing (.624) other then spring life....
engineermike
02-21-2005, 06:55 PM
I'm running that cam with 1.6 on the intake and 1.52 on the exhaust.
RealQuick
02-21-2005, 09:42 PM
Jeremy, check your pm's.
