LtsRace
02-17-2005, 10:38 PM
My paint is in overall good condition, but that little strip between the t-tops is faded. i tried waxing and using mothers back to black. still dosent work. any ideas?
That black strip between t-topsLtsRace 02-17-2005, 10:38 PM My paint is in overall good condition, but that little strip between the t-tops is faded. i tried waxing and using mothers back to black. still dosent work. any ideas? gt_biker13 02-18-2005, 04:19 PM I dont have t-tops so what is it? Just black paint or plastic? MustangEater82 02-18-2005, 10:31 PM black paint, similar to the little triangle on the back of the door. If you are interested, I have another one if you want... I'll check the paint and all and take pics for you if you are interested in replacing yours. $30 shipped if its in good shape? Its only 8 screws away to take it off and put another one on. :) If I shipped it it woudl likely get there in like 2 days, I just shipped a part to tampa that fast UPS ground and Ocala is closer then that. WhiteboysZ28 02-19-2005, 09:30 AM Dude just go to the store buy some of those green scotch bright pads , some good primer , & some good black paint. take the T-tops out mask off the area that you dont want paint to get on , use newspaper . then scuff it up real good clean the surface with some laquer thinnner , prime it with about 3 Very light coats take your time dont rush it , & dont try to cover all at once , let dry well then coat it with the black same steps dont try to cover all at once light coats. & your done . Any questions PM me JOSH MustangEater82 02-19-2005, 10:28 AM I never trusted carstore paint cans for the exterior... but if you do, do that, I'd just take it off and do it, it would make it easier to get all angles. Its only 8 screws all along the top. WhiteboysZ28 02-19-2005, 11:07 AM Ya duhhh me . Take it off , I just use dupliclor from autozone primer , paint then clear it works great!!! JOSH ZaneO 02-19-2005, 11:50 AM A good paint polish should revive it. Menzerna, Klasse AIO, Poorboy's, etc. LtsRace 02-20-2005, 01:41 PM Sweet, I think ill take it off and try polishing it out. If that doest work Ill try painting it. Thanks for the ideas! ZaneO 02-20-2005, 01:50 PM Try polishing it before you spend the time removing it. Zaino guy 02-22-2005, 05:34 PM It's black plastic just like the triangles above the doors. I use plastic polish on mine. | ||
