dkeers
10-10-2002, 06:16 PM
I just pulled my lid (stock) of to check my air filter and it seems to be letting a lot of things though. My MAF screen had stuff all over it: a small bug, 2 blades of grass, and other misc. small debris. Is this normal. I don't see how it can be. If debris big enough to get caught on the screen can get through, I can only imagine how much stuff gets through that the screen cannot catch. BTW everything in front of the MAF is stock (ie no FRA etc.). This is the second time I have cleaned the screen in the first 5000 miles on the car. Am I worrying about nothing or is something wrong?
Dustin
I don't know a whole lot about ls1s and their intake, but'd I definatly say there is something wrong.
CalvertLS1
10-10-2002, 10:24 PM
well if your running a stock filter , it may let stuff that big through? i dont know because the first thing i did to my car was a K&N filter.
you need a new filter, you might as well get a holley or K&N now.
also clean you MAF screen
dkeers
10-11-2002, 01:49 PM
I have cleaned it off twice now (only 5000 miles on the car). I will be getting a lid w/ holly filter soon. Hopefully this problem will disappear.
Nathan1234
10-11-2002, 04:54 PM
This is not normal. Something is broken. Your MAF screen SHOULD NOT be acting as a filter under any condition.
nikkev
10-11-2002, 05:20 PM
Make sure your intake is sealed all the way.That is definately not right :eek: Good luck.
Kevin
z28chrizz
10-11-2002, 05:33 PM
I had that... found out the oem filter wasnt sealing completely around the rear edge of the box. My Direct flo lid squished it down farther and the problem ceased. I am also way beyond the OEM filter at this point, and have found the fram seats nicely.
Good luck!
