lindsZ28
02-12-2005, 11:27 PM
Hello, everyone- this is my 1st post here, and sadly, its not a good one :(
Yesterday, I started my car, she turned over, then died. The clock reset, but everything else worked. I let her sit for a min, then started her up- fine. It happened again twice today. But, I have started my car up a few times today w/out any probs. Please help!!! Thanks everyone!!!
Lindsey
Fuels94TA
02-12-2005, 11:44 PM
Check the connection on the battery post to see if they are loose. A loose connection will make that problem happen. Also a dead battery cell might be the problem.
shoebox
02-13-2005, 12:48 AM
Help yourself and others by making a short signature that shows basic info about your car (at least year, model, transmission and any other pertinent mods).
lindsZ28
02-13-2005, 01:03 PM
Thanks . . . did it :)
86LT4Z
02-13-2005, 01:26 PM
I would suspect the battery if its the original Delco one.
lindsZ28
02-13-2005, 03:32 PM
I checked the battery, connections, etc. - EVERYTHING is fine. So, now I'm completely stumped. The car is still cutting out when I try to start it, then will start right up on the second try. :mad:
Fuels94TA
02-13-2005, 05:43 PM
Since you check the connection how about the post are they dirty with acid build up? Might have to take the battery out and have it tested for a bad cell. Also I just wanted to make sure your saying that the radio/clock would reset it self every so often.
