hatch struts install?
luckyxiii
02-12-2005, 10:19 PM
hey all, my hatch struts are dead....i can see that the b pillar side is held on with a torx, what about the hatch side? are there any specific things to look out for during the install?
thanks
13
shoebox
02-12-2005, 11:05 PM
On the hatch side, you have to remove a spring clip, then you can take the weight off the strut and pull it out. One strut will not hold the hatch up, so have something that you can prop it open with (or have a second person helping).
luckyxiii
02-13-2005, 02:05 PM
thanks shoebox,
ill check it out when its not rainin....i did a search and didnt see much on the topic. one more question: are aftermarket struts usually ok or is that another part that falls into the "dont buy from advance" category?
13
shoebox
02-13-2005, 02:22 PM
A decent aftermarket part should be ok, IMO.
87DJP2001
02-13-2005, 04:19 PM
Be carefull of that Hatch, you don't want a couple of hundred pounds dropping on you. :o
