Am I missing anything?
Old Feb 12, 2005 | 12:56 PM
BlackZ28Camaro's Avatar
Ok I am getting ready to order all the parts I will need to put together the new ls1 engine I am building. I plan on ordering all my parts from www.gmpartsdirect.com This is my very first engine build and I want to make sure I am not missing anything. So here is the list I have so far of things I need to order.
Front cover gasket Part #12574294
Front cover seal Part #12561254
Front cover bolts Part #?????????
Rear cover gasket Part #?????????
Rear cover seal Part #?????????
Rear cover bolts Part #?????????
Valley cover gasket Part #?????????
Valley cover bolts Part #?????????
Oil pan gasket Part #12558760
Oil pan bolts Part #?????????
Exhaust manifold gaskets Part #12558573
Exhaust manifold bolts Part #?????????
Flywheel bolts Part #?????????
Valve cover gaskets Part #12560696
Intake manifold gaskets Part #?????????
Water pump gaskets Part #12559271
Crank pulley bolt Part #12557840
Head gaskets Part #?????????
Head bolts M-8 Qty 10 Part #12558840
Head bolts M-11 Qty 4 short Part #12560745
Head bolts M11 Qty 16 long Part #11588291
Crankshaft main bolts Part #?????????
Crank bearings Part #?????????
Rod bearings Part #?????????
Piston rings Part #?????????
Should I go with another brand of bearings and rings other than GM? Or are the GM bearings and rings just fine?
I know I can reuse the old cover bolts but I have already got replacement covers because I want to complete the engine as much as possible before I pull my old engine. So I have listed all the part numbers I have been able to find in the internet and here on are website so far. So if anyone knows anymore part numbers that would be great.
So please let me know if I have overlooked anything. Thanks all.
Joel
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
