pHEnomIC
02-11-2005, 10:25 PM
MY dash seems to have a light not working. on the right side, at night the fuel level and guage next to it dont iluminate and are very hard to read. How do i go about replacing this and if it's too hard, should i not even try?
shoebox
02-12-2005, 12:59 AM
If it uses bulbs like a 1995, remove the cluster (http://shbox.com/1/cluster.jpg) and replace the bulb(s).
Z95m6
02-12-2005, 01:13 AM
I believe your 97+ camaro is the same as my 93 TA dash. If so you just pull out on the trim around the cluster and it will pop out. Then you have to fish i out from between the column and the dash. Then you just remove 4, 7mm bolts and yank out on the cluster. It can be kind of stuck in there but if you have the bolts out just yank and it will come out. Then you just replace the bulb you need. Now is the time to order some diff color LED bulbs if you want your dash to light up diff colors.
