Huntr1117
02-11-2005, 11:53 AM
About to get a set of Lower control arms and a panhard rod and I was just wondering how hard they are to install. Any tips or links would be great thanks.
Installing LCAs and PH Rod ?Huntr1117 02-11-2005, 11:53 AM About to get a set of Lower control arms and a panhard rod and I was just wondering how hard they are to install. Any tips or links would be great thanks. teke184 02-11-2005, 12:05 PM 4 bolts on the LCAs and 2 on the PHB.... my stock bolts were 17mm i think, and the replacement ones that BMR sent were 18mm i beleive. the LCA bolts are a little tricky to get to with a socket wrench...have an end wrench handy. do one side at a time with the LCA, and a second person is helpful to move the axle if it shifts. OBE1 95Z28 02-11-2005, 01:16 PM The bolts on the PHR only go through the bracket one way, so pay attention when you remove them. Huntr1117 02-11-2005, 08:42 PM Should I jack the car up when I do it or not? NastyTA 02-11-2005, 10:44 PM Should I jack the car up when I do it or not? Absolutely!!! Jack it up and support it on the frame, not the rear. Take one side off at a time. The stock bolts/nuts are 18mm. Take them out, drop out the lca, put the new one in. A good size pry bar helps line everything up. The PHR bolt head is a 13/16 and the nut is an 18mm. You may have to remove the pass side coil spring to get the bolt out since it goes in through the back. 97FormulaWS-6 02-12-2005, 08:25 AM One thing to add to this, is DON'T fully tighten the bolts when you re-install them. You want the car's weight on the suspension when you torque the bolts all the way down; this helps the suspension move properly and helps prevent squeeks. Huntr1117 02-12-2005, 02:44 PM Just finished installing the LCAs and the PHR this morning. It was pretty easy, it just took me a while because my driveway is slanted and my car sits pretty low. Thanks for everyones help :D GMH94Z28 02-12-2005, 05:25 PM Huntr1117, I am thinking of changing mine out to. Did you notice a big difference? Huntr1117 02-12-2005, 07:24 PM The rear seems to be more stiff especially around corners. The overall ride quality seems smoother too. I haven't had a chance to get on it yet, so I don't know if it helped with traction or not. I think that it was money well spent. | ||
