2 questions from a new owner
Old Feb 8, 2005 | 11:55 PM
Cannoneer's Avatar
I just bought this '96 3800 AT, and below the lighter there's a switch that says 2nd gear start, what is it? Also, I just bought a replacement dimmer switch for the headlights, how do I get to the old one?
Old Feb 9, 2005 | 09:15 AM
6SpdLT1Z's Avatar
Re: 2 questions from a new owner
I'm assuming 2nd gear start is skip shift, which was a option for your car. You use it when you can't get any traction like in the snow.
Old Feb 9, 2005 | 11:46 AM
valter's Avatar
Actually when you turn this mode on (button lightens) from stop your tranny starts shifting from second gear. Try turning it on and you feel what I mean. It's supposed to be for slippery conditions or something, but I can't find it useful.
Old Feb 9, 2005 | 08:02 PM
oil pan 4's Avatar
It's a snow thing, I see it on quite a few cars in Maine.
Old Feb 9, 2005 | 10:25 PM
Cannoneer's Avatar
Ok, I got the 2nd gear start thing figured out, thanks. Now about the headlight dimmer switch...How in the name of GM do I get to it?
Old Feb 10, 2005 | 05:39 AM
oil pan 4's Avatar
Now for the dimmer switch I think you will just have to start pulling stuff off.
Old Feb 11, 2005 | 03:35 AM
94Camaro's Avatar
the 94 / 96 interior is identical. to get to the dimmer switch, you have to remove : the lower kickpanel under the drivers side, the dashpanel (above the cluster -- large flat piece of plastic, be extra careful not to break the heater vent (its very easy to do), and the cluster housing itself. (cluster housing = the piece of plastic that is around the guages / over the steering wheel / in front of the whole dimmer/lights/everthing switch.)
good luck with it and just be careful. only took me like an hour or so to get mine off.
Old Feb 11, 2005 | 03:52 AM
Cannoneer's Avatar
I thought the dimmer switch was inside the steering colum, I dim the lights with the turn signal lever.
Old Feb 15, 2005 | 12:20 PM
94Camaro's Avatar
uhhh...in the camaro? are you talking about the headlights or interior lights.
guess i was thinking interior (havent heard the headlight switch referred to as a "dimmer")
capebuf
Jan 13, 2015 07:22 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
Injuneer
Dec 15, 2014 09:36 AM
