qukz28
02-08-2005, 05:48 AM
I made the first trip with the car Saturday. The car has 3.73 gears, 58 mm TB, LT4 Hotcam, and 1.6 RR. The PCM is stock, havent even changed it for the gears so it hits the rev limiter before shifting. This was on street tires and the car spun a little. What would these times be in the 1/4 mile, 1/4 mile MPH. Do any of you know what the car should run if tuned and with a good converter and sticky tires. Thanks :bow:
First Pass: Second Pass:
60': 2.117 2.100
594': 8.368 8.410
1/8 ET: 8.931 8.980
1/8 mph: 79.92 78.93
93LT1355
02-08-2005, 10:36 AM
I don't know if this helps but I ran a 8.957-1/8, when I ran my 13.930-1/4,but with the hotcam you would probably start gaining on the top end of the track so you would end up running faster than 13.9 and I'd say with a good tune and a converter you would see those times drop alot.
Fast Caddie
02-08-2005, 02:21 PM
Get some headers first!!! Then a tune, higher stall, and you're looking at low 13s/high 12s easily on a good tire.
ChevyTuffD.A.
02-08-2005, 06:53 PM
I ran a 8.76 at about 78.6 mph with the mods in my sig but with 2.73 gears and no tune. U for sure need to get that thing tuned and watch your times plummit.
qukz28
02-09-2005, 06:08 AM
Right now I am working on getting a set of headers, Laptop, LT1 Edit, and converter. Thanks for the info. :bow:
maxboosteric
02-09-2005, 05:16 PM
I ran a 60' 2.01
1/8 9.0 @ 78
1/4 14.01 @ 99
That was before the tune.
chewbonger93z28
02-13-2005, 07:45 PM
you deffinatly need a tune because thats what my car runs stock
qukz28
02-13-2005, 11:27 PM
Yes i know i definately do need a tune.. I had a 95 that ran 8.67 at its best with exaust and gears only.
