tunercat shift point questions need help
Old Feb 7, 2005 | 08:00 PM
94irocz's Avatar
Ight I have 3.42's and a 2800 stall along with a cam and other supporting mods. Went to the track yesterday and got new bests but for some reason I think it might be shifting early. Peak power is at 6400 rpms. Right now the kickdown up/down shift points are set at 1-2 38mph 2-3 66mph 3-4 126.
Seeing this and then lookin at the mph vs rpm calculator 38mph is 5200rpms, 66mph is 4800rpms and 3-4 is 5650ish.
That looks to me likes its shifting way early. Is this right or am I missing something? Any help or info you can give me would be greatly welcomed.
Joe
Old Feb 7, 2005 | 08:34 PM
DieKnow's Avatar
Re: tunercat shift point questions need help
What is your upshift rpm set at?
Old Feb 7, 2005 | 09:04 PM
94irocz's Avatar
Is that in the same table as the other three numbers I stated? I guess I really need to know is, am I shifting at 6400 1-2. And I think I should shift around 6200 2-3.
Joe
Old Feb 7, 2005 | 11:13 PM
97Z-M6's Avatar
this is the formula for scaling the shift tables. its (old gear ratio / new gear ratio= number to scale by.
ex. 3.23 / 3.42 = .94444444
if you have tuner cat all you do is hightlight the whole table and right click then click on scale and put .944444 and hit ok. and it will change the shift points.
what was you origanal gears 2.73 or 3.23.
Old Feb 8, 2005 | 06:04 AM
94irocz's Avatar
It was a 3.23 car. What table do I do that in? And will that be sufficent for a none stock car? And does it matter then I went from 3.73's back down to 3.42's?
Joe
Old Feb 8, 2005 | 05:04 PM
94irocz's Avatar
So if the old gears were 3.73's and the new ones are 3.42's I go
3.73/3.42 = 1.090643
Is this right?
Joe
Old Feb 9, 2005 | 10:43 PM
94irocz's Avatar
Ttt
Old Feb 9, 2005 | 11:34 PM
redcamaroz28's Avatar
I was just about to post the same thing. Mine read 1>2 39mph (5000rpms); 2>3 81mph (5550rpms); 3>4 139mph (5900rpms).
3-4 shift seems right, but right now my car shifts @ 5800 in every gear. This is off my stock tune. My friend's Z28 also reads the same.
To change shift points should I just add x mph to get the desired shift point w/o using this rpm/mph calculator: http://www.f-body.org/gears/
Old Feb 10, 2005 | 02:49 PM
LWillmann's Avatar
Joe
I have 34, 70, and 120 in mine. I'm running basic bolt-ons with the stock stall and 3.42s
Old Feb 10, 2005 | 05:12 PM
94irocz's Avatar
I have a cam, a 2800 stall, 3.42 gears and nitrous. Anyone suggest a good number to get me to where I wanna shift 1-2 6400 2-3 6200? Car will trap over 120 in third on the gas
Joe
Old Feb 10, 2005 | 06:07 PM
LWillmann's Avatar
Try: 45, 85, and 138 and see what you get.
jb4xx
Feb 2, 2015 10:00 PM
cmdeshon
Dec 27, 2014 10:06 AM
Sarahrope64
Nov 27, 2014 11:17 AM
STS-Formula
Jul 26, 2002 01:35 PM
