Washer fluid sprayer dribbles, not sprays
Old Feb 4, 2005 | 01:07 PM
Shempy's Avatar
The driver's side windshield washer fluid sprayer works fine. However, the passenger side just dribbles out the hole.
Any ideas? stick a pin in the hole (carefully)?
Old Feb 4, 2005 | 01:42 PM
anasazi's Avatar
Re: Washer fluid sprayer dribbles, not sprays
you use the washer fluid?
i don't even know if mine works or not
Old Feb 4, 2005 | 02:00 PM
Shempy's Avatar
I discovered it after driving down a wet, salted interstate. Bad time to find out it doesn't work. Not that I expect a Floridian to sympathize.
Old Feb 4, 2005 | 02:08 PM
camarobiatch
Guest
Posts: n/a
It may have debris in it try cleaning it out also make sure there are no pieces missing (check against other side)
Old Feb 4, 2005 | 03:09 PM
anasazi's Avatar
nah i just don't trust windshield cleaner on my paint
Old Feb 4, 2005 | 04:26 PM
Stang Spanker's Avatar
Both of mine shoot over my car and hit my decklid :blah:
Old Feb 4, 2005 | 11:08 PM
99andMine's Avatar
Try using a tooth pick. Most of the time this is caused by very small debris that gets caught and collects to the point where it gunks it up. And as far as spraying over your car onto the decklid...thats a little free flowing id check and make sure that you have some sort fo head left on that thing and not just hose.
Old Feb 5, 2005 | 07:54 AM
Z28Nut's Avatar
Disconnect the washer fluid hose and blow air through it from the nozzle side. You want to blow the debris out the hose side or it may get really stuck in there..
Old Feb 8, 2005 | 08:06 PM
Bayer-Z28's Avatar
That, and the crap you've washed off the windshield goes all over the rest of your car. Or on your leg if the windows are down.
Jeff1904
Jun 5, 2016 05:00 PM
blac94Z
Nov 4, 2015 01:59 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
damnyankee36
Sep 9, 2015 07:06 PM
