stmz28
02-02-2005, 10:25 PM
What would be a good Clutch to put in a 450 houre power ls1 car on the street. the car will be raced with sticks. I was reeding about Centerforce and spec ones what do you think is good.
Clutchesstmz28 02-02-2005, 10:25 PM What would be a good Clutch to put in a 450 houre power ls1 car on the street. the car will be raced with sticks. I was reeding about Centerforce and spec ones what do you think is good. Valkyn71 02-02-2005, 10:31 PM Spec stage 4 David @ Thunder 02-03-2005, 12:43 PM What would be a good Clutch to put in a 450 houre power ls1 car on the street. the car will be raced with sticks. I was reeding about Centerforce and spec ones what do you think is good. I would recommend the SPEC III clutch or the RAM 98931HD. Either will give you great driveability for the street but hold very well at the track when using slicks. The Centerforce is pretty comparable to a SPEC stage II, which really won't be enough. A key component in LS1 clutches is upgrading the hyrdraulics. We recommend the Mcleod master cylinder and newer 01-02 GM slave. Without upgrading these parts, you can pretty much bank on having release problems at WOT. ftransam1 02-03-2005, 02:43 PM definetly get the ram clutch totally worth it stage III | ||
