FS: New Jesel Comp Series Rocker System 1.6
Old Feb 1, 2005 | 02:14 AM
JWINN's Avatar
I have a brand new, never used complete Jesel Comp Series pedestal rocker assembly with 1.6 intake and 1.6 exhaust, still in orginal Jesel Box.
These will fit AFR LT1/LT4 165cc runner thru 225cc runner heads as well as some of the standard 23 degree SBC heads available. The Jesel part number is # KCS-01001
If your looking to reduce valvetrain adjustment intervals and want a rocker assembly that will keep valves lashed longer as well as give precision valve train geometry and keep valve train stable at high rpms when running larger lift cams then look no further.
Retail price $1,000.00
Your's for $600.00
If interested or need additional info pm me or your welcome to call me at 616-813-9296
Take Care,
Jim Winn
Old Feb 1, 2005 | 07:36 AM
Van's Avatar
Van
Re: FS: New Jesel Comp Series Rocker System 1.6
For what heads?
Thanks,
Rob
Old Feb 1, 2005 | 10:13 AM
JWINN's Avatar
These are Jesel part #KCS-01001 for Air Flow Research LT-1 heads, 165cc to 225cc runner as well as quite few other SBC 23 degr heads. They will also work on standard OEM LT1/LT4 head assuming the cylinder head has to machined for them.
Old Feb 1, 2005 | 10:22 AM
Van's Avatar
Van
What's the offset on the intake?
PM'd ya.
Thanks!
Rob
Old Feb 1, 2005 | 10:35 AM
JWINN's Avatar
I do believe they are .220 intake offset.
Old Feb 1, 2005 | 08:08 PM
Van's Avatar
Van
Dang! I need a .375 offset...... Good luck with the sale!
Old Feb 2, 2005 | 01:43 AM
JWINN's Avatar
Thanks,
Jim
Old Feb 3, 2005 | 06:44 AM
383Z's Avatar
Will these work on regular AFR SBC heads. I have a l98
Old Feb 3, 2005 | 12:49 PM
JWINN's Avatar
They will in fact work.
Call me I will work ya sweet deal.
Old Feb 13, 2005 | 01:56 AM
JWINN's Avatar
Still available.
Old Feb 14, 2005 | 08:55 AM
Dave69Z's Avatar
I would be all over these if they were setup for the 60/40 split for AFR 227s.
Too bad you couldn't exchange them for that P/N.
Good luck with the sale.
Dave
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
Spcquinn
Apr 10, 2015 04:02 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alphaauto
Jan 23, 2015 07:42 AM
