Middle Atlantic New Jersey, New York, and Pennsylvania
1988 IROC Z WHite PARTING OUT* + extras
Old Oct 9, 2002 | 05:11 PM
djk19's Avatar
Talking 1988 IROC Z WHite PARTING OUT* + extras
* PArts are from a White 1988 Chevrolet Iroc Z-28 305 T.P.I. *
Dr. side fender $50.00
85-90 style Front nose assembly $175.00
Pas. side door (white) manual windows, tinted, nice beige door panel $100.00
rear center lighted spoiler piece $35.00
Back hatch w/ NO rust on rim $150.00
Hatch Pulldown Asembly $35.00
pas. side gfx piece $35.00
rear side gfx (R) $25.00
rear side gfx (L) $25.00
Rear Bumper Cover $45.00
Fiber Light Bar Assembly $50.00
Front honey Comb bumper with beam 75.00
Rear honey comb bumper with beam 75.00
Air box Assembly for TPI. $75.00
IROC style tail lights (2 Passengers side available, no sets) $35 each
Almost Mint condition original leather steering wheel with perfect horn button. $150.00 Garunteed Very nice.
Center Console w/ auto shifter plate
Nice dash pad with slight tiny crack on dr. side problem corner, not a chip. I was going to fix it with vynil repair but don't need to now. Good ones go for one hundred dollars get this one and fix it for pennies. Easy fix $40
1 COMPLETE T.P.I. SEtup !
PAckage comes with Computer, stock wire harness with no modifications and in great rubbery condition, Un-ported plenum, mint runners, clean un-ported basepate,waterneck, Fuel rail assembly with reconditioned tubes, polished rails and regulator assembly, stock 48 mm TPI throttle body. Everything you need to convert your car to an 88 IROC style TPI. All you need are new gaskets for the throttle body, fuel rails/injectors and waterneck and it's ready to be bolted in !! $1000 b.o.
Window wiper motor assembly in great condition $25.00
gas tank w/ pump assembly $125.00
10 bolt rear drum to drum $125.00
Nice working 700_R4 trans 450.00
305 roller, centerbolt heads, 2 bolt block $450.00 50k.
Engine has NO ring wear.
American Eagle 15" x 8" polished five star rims, bought new and installed by Direct Tire. Car was driven 100 miles and wheels were removed. One rim has slight curb rash. ONe rim never installed and brand new! Other two are installed once but LIke New*.
1 set of white chipped 15 x 7 stock IROC style rims. $100 or b.o.
1 Fiberglass IROC Turbo Daytona style hood. Purchased new for $500 painted white, vents are still black and side air ducts have NOT been ported out. Pin down style. This hood is an eye catcher. $350 b.o.
also available: set of stock lower control arms, stock panhard rod, stock torque arm, many black and beige interior trim, non t-top car.
Old Oct 16, 2002 | 03:24 AM
ZZ's Avatar
ZZ
I'm not trying to be critical, but rather just offering some advice. I think that a grand is pretty steep for a TPI setup. I got two of them for under 300 each, including ecm, harness, maf, and everything from the intake on up including injectors and fuel rails. Now if you have the motor attached...
Old Oct 16, 2002 | 03:22 PM
djk19's Avatar
Yea there is a 305 attached to the TPI with center bolt cast heads, very low miles. WEll then i'll sell my TPI setup for $350 for the whole kit and any extras that are needed. I just need to get rid of this stuff. Everything goes in the want ads locally soon.
Old Apr 24, 2011 | 04:52 PM
scottyman89's Avatar
Re: 1988 IROC Z WHite PARTING OUT* + extras
i was wondering if you still had the wiring harness for the car and if so how much you would want for it
mr28
Apr 20, 2016 05:44 PM
rockync7
Jan 1, 2015 05:10 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
mr28
Nov 23, 2014 11:11 AM
