New to drag racing *help*
thelastz28
01-30-2005, 08:26 PM
I have a 2002 Camaro Z28 A4. What is the way to race automatics? Overdrive? or all 4 gears? Please help, Thanks. :D
LS1_03
01-30-2005, 09:48 PM
After your burnout, leave it in 3rd(D). Reason: Doesn't matter if it's in OD or D. But, if you leave it in D the engine will help slow you down after you cross the stripe.
As for launching, find a backroad and practice different launch RPMs.
Capn Pete
01-30-2005, 11:35 PM
Like he said, put 'er in Drive and GO!:thumb: "Manually" shifting your automatic will only help (with electronically controlled trannies) in a few circumstances:cool:. Get a programmer if you need to raise/lower the shift points.....shifting at just the right time has gained/lost me ~.2 seconds in the 1/4 mile before;).
thelastz28
01-31-2005, 12:00 AM
D or OD doesnt make a difference in speed? Thanks. :confused:
Stephen 87 IROC
01-31-2005, 12:13 AM
Theoretically the tranny will keep the line pressure higher while in D than OD but I can't find any proof. If the car is set up properly, you'll never use OD in the 1/4 mile. You shouldn't be using OD in the 1/4 mile anyway because the OD gears are small and weak.
thelastz28
01-31-2005, 12:22 AM
Thanks for all your help guys. :D
Capn Pete
01-31-2005, 08:35 AM
I've heard the same thing, but I've tried running in both D and OD, and never seen a difference on the time slip that I could credit to that theory;).
As far as running into 4th gear in the 1/4 mile, I've never hit it (yet:p) even running 4.10 gears:thumb:. Not until you're running upwards of ~120 mph do you need to look at ways of staying out of 4th (higher rev limiter, bigger tires, or taller gears than 4.10) :cool:.
thelastz28
01-31-2005, 08:08 PM
Thanks, one more question. Why do they burnout before a race? :confused:
Capn Pete
01-31-2005, 11:51 PM
For guys with slicks, it's real important to heat them up so they'll stick.....the hotter the rubber gets, the stickier it gets, and sticky = traction;).
You will see a lot of guys warm up their street tires too (I've done it with my car and seen positive results), but as a rule, street tires don't get any stickier when they're hot.....it's just a beneficial sometimes to clean them off before you run. With the tires I'm running now though, it did actually help to warm them up.....I cut a 1.92 60' time with my Hankook's!!:D Track prep was awesome that day though:thumb:.
00ls1
02-01-2005, 04:28 PM
also just to help in first gear your gonna have to hold yourself back from puttin the pedal to the floor... traction is everything out of the hole just remember that
thelastz28
02-01-2005, 06:29 PM
Thanks again. But, first gear? I hava an A4 2002 Z28. :cool:
00ls1
02-01-2005, 07:30 PM
well you still have a first gear in that auto.. haha i know what you mean but you can spin those tires almost as easily as us m6 guys so out of the hole feathering that throttle will be important
five7kid
02-02-2005, 10:29 AM
Up to a point. That point is determined by track temperature (which is why you often see a crew member out there with a pyrometer). Most non-professionals get their tires too hot. When I asked the manufacturers about the burnout required for DR's (BF Goodrich) and Quicktime Pro DOT's (Hoosier), the response was the same: "Don't do a burnout. Just turn the tires enough to clean them. The traction is in the compound."
thelastz28
02-03-2005, 09:18 PM
Good tips, I'll try them when I go to the track. :D
SFB767
02-04-2005, 09:26 PM
Here's the best way to drive your A4 at the track.
First of all, don't manually shift an automatic transmission, you're just wasting your time and you may damage the transmission.
Your very first pass
1. Make sure your traction control is turned off
2. Totally avoid the water box and don't do a burnout
3. When the light turns green, just take your foot off the brake and leave at idle without spinning, just to get a feel for how things at the track work
When you're comfortable launching hard
2. Drive up to the tree and stage
3. As soon as the 2nd stage light comes on, put your left foot on the brake and press the acclerator to about 1,000-1,000 RPM with your other foot
4. As soon as the yellow light flashes, take your foot off the brake while leaving your right foot in the same position and you'll feel the car bounce forward
5. As soon as you feel your tires grab traction (this could be right away or after minimal wheelspin) just floor it, point the car straight and hold on
It will take practice. I used to always get 2.3-2.2s, but since I've practiced launching, I can now get 2.1-2.0s without even burning out.
Good luck at the track. :cool:
thelastz28
02-05-2005, 02:34 PM
I will try it with the Traction Control off. I just have to wait until the California Speedway opens again to drag racing. Thanks. :D
thelastz28
02-09-2005, 08:44 PM
Tomorrow I will be visiting Irwindale Speedway for my very first drag race. I am excited to see what my times are. I am not sure if I will be running the 1/4 mile or the 1/8 mile. I dont know if they have the 1/4 mile there. But either way I should have some fun. :D
MotorCityNova572
02-09-2005, 09:37 PM
Good luck man......if you need any help go over to the Michigan message board.....there is guys over there that have been drag racing for over 30 years....Tanner is a good person to ask.....HotrodHawk is a nother good guy...and many many other guys are good to ask this is a good site of advice for drag racing.and again good luck tommarow....hope you win...... :death:
thelastz28
02-10-2005, 12:05 AM
Thanks MotorCityNova, I will post up my results hopefully tomorrow night. ;)
P.S. should I remove my spare tire "donut" and jack before I run? Thanks again Nova.
LS1_03
02-10-2005, 10:41 AM
It'll shave off about a tenth.
MotorCityNova572
02-10-2005, 05:18 PM
Yea....you should take off all the stuff you ant goin to need everyday.like the jack and donut.....but i would say put them back in after the race...i have never drag raced....but i just know a lil bit about it from friends and TV shows...
thelastz28
02-11-2005, 08:36 PM
I got in two runs on Thursday before they canceled the races because of the rain. They were only 1/8 mile, not 1/4 mile. The first one I totally messed up. I guess I was between D and OD and I went no where and got 11.963 ET :cry: and the second one wasnt that good either I got 9.112 ET. I need to go back and practice, until I get the hang of it I guess. I suck at this drag racing stuff. :mad:
LS1_03
02-12-2005, 10:11 AM
That 9.112 1/8 ET is good for low 14s in the 1/4. Unless you have some wicked top end. :p
thelastz28
02-12-2005, 07:07 PM
Low 14's isnt that good an ET for an LS1 powered F-body is it? I will keep trying to get a better 1/8 mile at the Irwindale Speedway, until I get a chance at the 1/4 mile at the California Speedway. ;)
LS1_03
02-12-2005, 08:28 PM
Well, it WAS your first time wasn't it? Don't beat yourself up. You'll be fine with more practice.
thelastz28
02-12-2005, 09:35 PM
Youre right it was only my first time at the track and all I have is an SLP lid and a Flowmaster exhaust. :barf: :D
MotorCityNova572
02-13-2005, 01:03 PM
9.112 is a damn good E.T
thelastz28
02-13-2005, 10:04 PM
Am I going to be able to get better times with my 2.73 gears?
MotorCityNova572
02-13-2005, 10:11 PM
that one i dont know.....
thelastz28
02-13-2005, 10:19 PM
Thanks M C Nova 572. ;)
LS1_03
02-13-2005, 11:16 PM
I have 2.73s. I hate them. :lol: I'm planning on swapping 3.73s in this year. 2.73s will be decent for hooking off the line. But if you're looking for better E/T, then 3.73s in an auto is what you want. I'll admit, 2.73s are pretty good for MPH in the 1/4 for a mostly stock car. :)
thelastz28
02-13-2005, 11:23 PM
Thanks LS1 03, I will eventually end up switching to 3.73s. :D
Spinner
02-22-2005, 11:49 AM
4.11 :)
ScreamnChicken
02-22-2005, 01:11 PM
4.11 :)
That is what I plan on going to once the 9" goes in:D
anthonycds
02-22-2005, 10:32 PM
It's a sickness isn't it? My first time at the track, ran a 13.7, then the second time out ran my best of 13.1. Experience will be one of your best tools. Ideal track conditions are always a plus, unfortunately it's not the same at every track. My goal for this coming spring will be to squeeze into 12.9 completely factory, with just over 9,000 on the odo.
thelastz28
02-26-2005, 11:01 PM
experience :d
Capn Pete
02-26-2005, 11:49 PM
Yeah:rolleyes:, 'til the track conditions go for a crap at the track you're used to running, and all the experience in the world can't save your 13.0 second car from running 13.5's or worse:(. Been there, done that, got the disappointing time slips!:irk:
