Need an extra 1/16" clearance on valve covers
Old Jan 30, 2005 | 06:18 PM
Erik's Avatar
Classic Tech Moderator
Can I double up on the valve cover gasket to give me just a wee bit more clearance? Any other suggestions for gaining clearance?
I'd just replace them with taller ones, but I did some custom CNC machining on them, and I'd rather not spend the time and money to buy and machine new ones.
Old Jan 30, 2005 | 06:29 PM
pHEnomIC's Avatar
Re: Need an extra 1/16" clearance on valve covers
They have valve cover spacers at summit racing. Search for it there.
Old Jan 30, 2005 | 07:01 PM
captaindbol's Avatar
Do you have centerbolt or perimeter style bolts?
Old Jan 31, 2005 | 12:04 PM
Z28SORR's Avatar
They also have a thick casket for this purpose.
Old Feb 1, 2005 | 12:27 PM
stale's Avatar
Double gaskets will more than likely leak without a metal spacer in between. Gaskets don't seal very well to eachother.
Old Feb 1, 2005 | 06:29 PM
Erik's Avatar
Centre bolt, cast aluminum.
Old Feb 2, 2005 | 11:39 AM
Find 2 of the thickest old school cork sbc gaskets you can get. Take a razor blade and remove the locking tabs, when you are done you will have the same profile as a center bolt gasket. Glue them together with a quality adhesive.
http://www.midwayauto.us/detailedpro...tion.asp?11553
This stuff makes regular RTV look like a red headed step child. It's over 2x the price for a reason. Kind of like 100mph tape vs. generic duct tape. Anyway.
Use a thin bead of sealant to adhere the gasket combo to your cover and let dry. While you are there fill in the gasket bolt holes with sealant and wipe clean, not letting any of the sealant get on the mating surface. After everything is dry install the covers barely over hand tight( cork does'nt need to be crushed to seal) and your done.
I hope this is helpful to you. BTW I have been using the cork sbc gasket on my cast cntr bolt covers forever with no problems. It seems most of the cast covers don't have as good of a retaining groove as the stockers and the stretch to fit felpro rubber gasket always manages to pop off during the install.
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
