DIY Wideband O2... anyone build one yet?
Old Oct 9, 2002 | 03:25 PM
stevil's Avatar
Do-It-Yourself Wideband O2 Sensor
Looks sort of cool.
I'd weld a 3rd O2 bung into my off-road pipe.
Old Oct 9, 2002 | 03:45 PM
BigDaddy's Avatar
I've built the one from www.techedge.com.au
Old Oct 9, 2002 | 05:50 PM
96z's Avatar
96z
If it worked right it sure would make things a hell of a lot easier.
Old Oct 9, 2002 | 11:08 PM
turbo_Z's Avatar
BigDaddy,
that sight was kinda confusing..what was the total cost for the system? and was it worth it?
do you have to remove the wideband when its not in use or do you just use it all the time to monitor the car?
Old Oct 10, 2002 | 05:47 PM
BigDaddy's Avatar
Techedge offers lots of different options. You can buy a prebuilt unit, or a kit, or just parts. I bought the kit, so I had to put it together, which wasn't a problem. I paid about $75 for the WB controller and the Display. I paid $128 for the sensor from thePartsBin. I have yet to put it in my car since, because I want to rebuild the motor first. I plan on putting it in passenger side pipe right after the header. I will not be leaving it in the pipe. I will install it when I'm tuning, and remove it when I'm not. If you leave it in all the time, the life of the sensor will be shortened, and it will need to be turned on when running the motor. Running the engine without the sensor powered will destroy the sensor quickly. I recommend you join the Yahoo group and mailing list. There are a lot of people who are using this kit, and are having great results.
Old Oct 12, 2002 | 11:09 AM
Arctic_White_WS6's Avatar
I too have built the TechEdge WBO2 with display. It is a high quality kit, great instructions on the web page, and was pretty easy to build. I can't say enough good things about the kit!
I got an O2 mount placed after the header flange on each side of the y-pipe. It allows me to swap back and forth and check each cylinder bank.
Old Oct 12, 2002 | 07:00 PM
stevil's Avatar
Yeah, that TechEdge deal looks good. Could be fun to build during the winter, won't be stuck in a cold garage modding...
Old Mar 11, 2003 | 10:19 AM
athens96ta's Avatar
I just finished building my Australian kit. Not too bad. Good quality components and instructions. Now, I just need to calibrate it and start tuning. How did you guys hook yours up? I've heard the A/C output is 0 - 5 volts and it could just be plugged in there for logging te voltage output of the sensor. Of course, this data would have to be converted to a/f ratio using MS Excel or something.
Loren
Old Mar 11, 2003 | 04:03 PM
BigDaddy's Avatar
You need to find out what the input resistance of the AC input is. It needs to be sufficiently different than the output resistance of the wideband unit, or there will be a voltage dividing effect, and the logged data will not be accurate and thus useless. You should ask about this in the yahoo group. It was discussed recently by Peter and some of the members.
Old Mar 11, 2003 | 05:54 PM
BigDaddy's Avatar
The output impedance of the version 1.5 wb is 100Ohms, so the input impedance of the AC port needs to be at least 100kOhms, or the voltage dividing effects need to be taken into account.
Old Mar 12, 2003 | 07:41 PM
CanadianZ's Avatar
Could a unit like this be hooked up to N20 solenoids to shut them down iif the car runs lean?? Theoretically, it should be possible. But how hard would it be to do?? Any thoughts??
CanadianZ
Old Mar 12, 2003 | 08:53 PM
This is quite easy to do. You could use an op amp as a comparator whose output would drive a relay that could kill the nitrous solenoids.
Old Jun 12, 2003 | 01:41 PM
Highlander's Avatar
Does buying the kit need stuff to be soldered???
Let me know
Old Jun 12, 2003 | 06:16 PM
Yes, quite a bit of soldering to do!
Old Jun 12, 2003 | 06:19 PM
Highlander's Avatar
Not that good with soldering skills so I'll just buy it complete...
