dochtermiatasbrother
01-27-2005, 07:37 PM
i need people's best guess, cause im going to run her real soon,like next thur soon.....
mods R /// Rebuilt Motor/Trans/
Del.Power steering/ del..A/c
Absolutely Nothing in Engine Bay but what is needed to run Car...
No Converter
New plugs/wires/cap/rotor
Trans Cooler
Dual Snorkel AIr cleaner/wich i wana sell
Ok please gimme your best guess's :confused: ;) ;)
Im thinkin 14.9-15.5
01-27-2005, 07:39 PM
O and ive heard Lowering the tire PSI at the track will help out...?? is this 2rue?
mako350Z28
01-27-2005, 08:10 PM
I'm thinking closer to 16 sec.
Lower tire pressures will work with drag or street slicks, but not with normal street tires because the sidewalls are too stiff.
EDIT: Also, the rubber they use for slicks is different than that of street tires.
01-27-2005, 08:20 PM
ouch/ anything better than a 15.9 ill be happy with ;)
JSkeet
01-28-2005, 02:57 AM
im gonna say 15.3-15.7 only because i ran my factory '84 LG4 (150 hp 240 tq) car w/ nothing but flowmaster catback and ran 16.1@83.6mph. this run was done nov. 2003 in perfect track/weather conditions. i even did a burnout w/ the 2.73 open diff... lol... anyway, i had owned the car almost 2 years myself and never replaced ANYTHING but oil.... could've been running on 7 cyl. who knows?!!... go for it man!!
if you can plumb some raim air for that dual snorkel i'd do it... check out a local HVAC center for some tubing... or to get ideas www.ramairbox.com
89305rs
01-28-2005, 09:32 AM
Well the L69 pushed the monte carloSS down the strip at a 15.7 so im guessing a 15.5-15.7
Red25thRS
01-28-2005, 11:58 AM
you should be able to get mid to low 15's.....i got a 92 rs 305 tbi auto....all i got done is full exhaust...open element air cleaner...junk jet stage 2 chip....throttle body spacer...and 3.73 gears and i hit 14.8....and that was with my timing retarded 12 degrees cuz my friend messed it up....so thats not to bad for a lo3 305
01-28-2005, 07:23 PM
Id like 2 break 14's then i would sh$t my pants....... :bow:
