What 2 step
slp223
01-27-2005, 01:19 PM
if you are running a two step. what brand are you running? thank you
Stephen 87 IROC
01-27-2005, 08:47 PM
MSD is the typical standard. Change the pills to the rpm you want.
I use a Holley Annihilator ignition with a built in 3 step but I don't use the burnout limiter. It's digital with a controller to change the rpm limits. No pills required.
huffin Z
01-27-2005, 11:38 PM
i got the msd digi. 6................you can do 2 step, timing retard........everything you need!! its perfect!
