LS2 Intake or LS6?
ShowandGo
01-26-2005, 01:21 PM
heres what I got.1998 Z28 TSP 231/237 cam stage 2 heads 125 shot 42 lb injectors 4400 stall ported tb and maf air lid what intake should i go with?
LT-14me
01-26-2005, 01:43 PM
Would an LS2 intake even bolt up? I know they are gen iv motors so i would assume some stuff has changed like you cant bolt an lt1 intake onto an ls1. :confused:
stik6shift93
01-26-2005, 01:50 PM
They fit, you need spacers for the fuel rails i believe and you need to use ls1 injectors.
Greed4Speed
01-26-2005, 02:13 PM
TB won't work unless you have drive-by-wire
stik6shift93
01-26-2005, 04:14 PM
Do a search on ls1tech.com in the ls2 section some guy there did it. The ls2 intake is a 3 piece intake, pieces don't line up perfectly so a little finish porting is required to smooth things up in the intake ports.
BirchMan98z
01-29-2005, 05:27 AM
Builders commonly use the ls6 intake on engines as large as 427. It's a top notch piece, and a cheap mod.
anasazi
01-29-2005, 08:14 AM
everything is relative ... :)
can't find one used for less than 300 bucks
Antz97ZNJ
01-29-2005, 09:13 AM
http://ls1tech.com/forums/showthread.php?t=265529
