A missing lugnuts?
ChrisUlrich
01-26-2005, 02:06 PM
If I had 4 out of 5 lugnuts on my rear tires... what would happen? Anything bad?
1-bad-z28
01-26-2005, 02:14 PM
nothing would happen...i wouldn't be doing too much drag racing but normal every day use wouldn't matter
RE AND CHERYL
01-26-2005, 04:47 PM
I would think you would replace the missing lug nut. :D
BUBBA
01-26-2005, 05:36 PM
Take some off the front wheels. The back ones are the ones that all the spinning. :cool:
redcamaroz28
01-26-2005, 05:56 PM
It'll be fine. My friend raced w/ only 3 one one tire :eek: then again, he's not the brightest fellow. Another friend had only 2 lugs on one wheel on his integra (4 bolt pattern) and drove around like that for bout 2 months.
shoebox
01-26-2005, 06:17 PM
LOL and the front ones do the steering. :D
pHEnomIC
01-26-2005, 06:58 PM
When i went in for a driver test, they require 4 out of 5 or 3 out of 4 lug nuts on each wheel or better of course. Right before my test i panicked because i knew they checked that and i noticed one was missing.
Why not get another set. autozone has em for a dollar each.
6SpdLT1Z
01-26-2005, 07:02 PM
It will be fine aslong as you don't launch too hard, or drive on the highway any... Go buy a new set or something though.
scooters97ss
01-30-2005, 11:16 AM
If by bad you mean the wheel working loose and falling off; then yes.
We had a Ford half ton in our shop recently that required over $2000 worth of repair and body work because a rear wheel worked loose. Safety inspection here requires all wheel studs and nuts to be in place.
