montytrmpt
01-25-2005, 06:48 PM
I've never been able to read the codes off of my car through the datalink. I got into the wiring (again) and today I found the white and black diagnostic enable wire was not connecting to anything. The blue connector under the passenger side kickpanel is where this wire is supposed to make its way through the firewall (I think). On my "IP wire harness" the white/black wire is in slot "c" of that blue connector. Its that way on this harness and on the old harness too. you can see it in shoebox's schematic here http://shbox.com/1/harness_connector_faces.htm The problem is, there is no white/black wire on the small harness that actually makes its way through the firewall. Are there differences in these harnesses? Did the wire get pulled out by a previous owner? I'm at a loss, I don't know where this wire should go now, and it would be really helpful troubleshooting current problems with that datalink working.
