Single Plane or Large Plenum Front-Inlet Intake Manifold for FI?
Old Jan 25, 2005 | 08:19 AM
Birdie2000's Avatar
I've seen both run before.
What are the advantages/disadvantages of running a single plane with a 90* and a throttle body over a sheetmetal or modified stock manifold with a larger plenum? I know the fitment issues, but let's talk about performance.
Old Jan 25, 2005 | 02:39 PM
Pro Stock John's Avatar
Re: Single Plane or Large Plenum Front-Inlet Intake Manifold for FI?
Intmd8 was last running a sheetmetal LT1 intake by RGR that he may have done a bunch of work to, maybe he will chime on on what he ran prior... LT4 intake?
Old Jan 25, 2005 | 10:03 PM
engineermike's Avatar
There's an interesting article in last month's MM&FF magazine (I'm not a traitor - just a spy) in which they tested a Vortech at 14 psi in an '03 Cobra motor both with the stock Cobra intercooler/intake, then with a Vortech Aftercooler and '01 intake. The difference is that the '01 intake has much longer runners than the factory SVT supercharged intakes. The long-runner '01 intake offered 60 more hp and 60 more ft-lb torque. Based on that, I'd lean towards the single plane due to the longer runners.
Mike
Old Jan 25, 2005 | 10:55 PM
Birdie2000's Avatar
How much of that do you think was because of the Vortech cooler? Either way, good information to know.
Old Jan 26, 2005 | 07:57 AM
The core for the Vortech aftercooler is roughly the same size as the SVT intercooler in the manifold.
Old Jan 26, 2005 | 11:58 AM
imnotfast's Avatar
Havent ran the stelth ram with boost yet but hopping to very soon. The plenum area is close to what the modded LT4 but the runners are 4.8 inches longer. Should hope to have some numbers mid to late Feb.
Old Jan 26, 2005 | 02:12 PM
Birdie2000's Avatar
Which would you guys think is more important, the runner length or the plenum volume?
Dennis, good to hear it's coming together! You engine dynoing it again? If so, where at?
Old Jan 28, 2005 | 09:26 PM
Hot Rod Hawk's Avatar
Runner lenght Jim.
Old Jan 29, 2005 | 06:53 AM
z28draco's Avatar
run a single plane do0d
Old Jan 30, 2005 | 06:20 AM
arnie's Avatar
Although somewhat muted in FI applications, it is important to consider seriously, both aspects. Also, AFAIC, important to not pick out just one aspect, of an intake manifold proven to be effective. That manifold reminds me of another manifold.
HarleyZ28
Oct 5, 2015 06:23 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
