limige
01-24-2005, 02:34 PM
hi wiring up a kit and don't have the schematic.
is it ok to run the hot from the relay to the pressure switch and into the heater, then ground the other heater lead? that's the right wiring right?!
just want to be sure it's done right.
thanks,
mike
MEAN_SBC
01-24-2005, 05:06 PM
Heater Wiring (http://www.nitrousexpress.com/Instructions/heater.pdf)
That has the clear schematic pic of it.....
If you need any more instructions, they are here:
http://rocketworldracing.com/store/Instructions.php
limige
01-25-2005, 07:07 AM
ok thats what i was afraid of, gotta have the relay next to the heater...
anybody know what amperage relay is required? heavy duty means what 30amp?
"White Knight"
01-25-2005, 08:29 AM
I always wondered, you have to run a positive back there, but do you just run it along side the nitrous line? Seems like it might be dangerous, but i don't know. Can you run everything back there off the relay? Like if you had a remote opener?
Nitro Dave
01-25-2005, 10:23 AM
The relay is a 40 amp.You can but the harness and relay together.
As far as running the wiring next to the main feed line.We run all our wiring in wire loom so there is no reason to worry.
Dave
limige
01-25-2005, 08:41 PM
so what gauge wire should i run back for the main feed on a heater?
white knight..
if you run a large enough feed line you can run multiple relays off it but don't try to run several things off one relay, your asking for trouble...
also, it's ok to run your power next to your braided line, why wouldn't it?? nitrous isn't flamable!
it's nothing like having your headers too close to your brake lines! lol
